Saltar al contenido principal
RazorX DLX Electric Skateboard Control Module Replacement
Emmett Normand
Emmett Normand y 4 otros contribuidores
Última actualización: December 30, 2024
7 minuto
Fácil
Guía de Estudiante Destacada
Introducción
Ir al paso 1
This guide is intended to show you how to replace the control module on the RazorX DLX Electric Skateboard. This guide may apply to later models of this skateboard as well. The control module communicates with the users remote control in order for the skateboard to properly function. When handling the control module, be careful with the wires and avoid any damage to the circuit board. Before you start, make sure the power button is switched to off.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. RazorX DLX Electric Skateboard Control Module Replacement, Battery: paso 1, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement, Battery: paso 1, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Control Module Replacement: paso 2, imagen 1 de 1
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Control Module Replacement, Control Module: paso 3, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement, Control Module: paso 3, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement, Control Module: paso 3, imagen 3 de 3
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Control Module Replacement: paso 4, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 4, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 4, imagen 3 de 3
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Control Module Replacement: paso 5, imagen 1 de 1
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Control Module Replacement: paso 6, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 6, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 6, imagen 3 de 3
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Control Module Replacement: paso 7, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 7, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 7, imagen 3 de 3
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Control Module Replacement: paso 8, imagen 1 de 2 RazorX DLX Electric Skateboard Control Module Replacement: paso 8, imagen 2 de 2
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Control Module Replacement: paso 9, imagen 1 de 1
    • Remove the Control Module by lifting it out of the plastic housing.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Emmett Normand
Miembro Desde 10/24/24
971 Reputación
8 Guías creadas
Equipo
Cuesta, Team 20-4, Krynen Fall 2024 Miembro de Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
Miembros de 5
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 58
