Saltar al contenido principal
Lenovo Yoga 6 13ALC6 SSD Replacement
Spencer Day
Spencer Day y 4 otros contribuidores
Última actualización: March 19, 2024
10 - 30 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the SSD on your Lenovo Yoga 6 13ALC6.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: paso 1, imagen 1 de 2 Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the lower case: paso 1, imagen 2 de 2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: paso 2, imagen 1 de 2 Lenovo Yoga 6 13ALC6 SSD Replacement, Insert the opening pick: paso 2, imagen 2 de 2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: paso 3, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: paso 3, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the clips: paso 3, imagen 3 de 3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: paso 4, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: paso 4, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Release the remaining clips: paso 4, imagen 3 de 3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 SSD Replacement: paso 5, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement: paso 5, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement: paso 5, imagen 3 de 3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 SSD Replacement: paso 6, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement: paso 6, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement: paso 6, imagen 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: paso 7, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: paso 7, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Disconnect the battery: paso 7, imagen 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: paso 8, imagen 1 de 2 Lenovo Yoga 6 13ALC6 SSD Replacement, Unfasten the SSD: paso 8, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 2.5 mm screw securing the SSD.
  9. Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: paso 9, imagen 1 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: paso 9, imagen 2 de 3 Lenovo Yoga 6 13ALC6 SSD Replacement, Remove the SSD: paso 9, imagen 3 de 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  10. Lenovo Yoga 6 13ALC6 SSD Replacement, Reassembly notes: paso 10, imagen 1 de 1
Conclusión
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Una persona más ha completado esta guía.
Spencer Day
Miembro Desde 09/14/22
95,018 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
Un comentario
Love how everyone says a 2280 won’t fit but the bracket all it does it converts the 2242 to fit in a 2280 slot lol. 2280 works just fine. Stuck an 8TB in mine.
GTAGriff900's Channel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 35
Ultimos 30 días: 127
Todo El Tiempo: 4,978
