Saltar al contenido principal
Lenovo ThinkPad T480s Trackpad Replacement
Sarah Westberg
Sarah Westberg y otro contribuidor
Última actualización: March 20, 2024
30 - 40 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the TrackPad in your Lenovo ThinkPad T480s.
The TrackPad (also known as a touchpad) translates finger gestures, such as swiping and clicking, to computer actions like dragging and scrolling, similar to how a mouse functions. If the TrackPad is not responding to any gestures or if your gestures are behaving erratically, your TrackPad may be faulty. Before attempting to replace the TrackPad, visit Lenovo’s troubleshooting manual for diagnosing TrackPad-related issues.
If you need to perform a replacement, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Qué necesitas
Partes
Herramientas
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Ver más…
  1. Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Trackpad Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Trackpad Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T480s Trackpad Replacement: paso 3, imagen 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Trackpad Replacement, Battery: paso 4, imagen 1 de 2 Lenovo ThinkPad T480s Trackpad Replacement, Battery: paso 4, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Trackpad Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 5, imagen 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: paso 6, imagen 1 de 3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: paso 6, imagen 2 de 3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: paso 6, imagen 3 de 3
    • Use the spudger to disconnect the trackpad cable from the system board.
  7. Lenovo ThinkPad T480s Trackpad Replacement: paso 7, imagen 1 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 7, imagen 2 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 7, imagen 3 de 3
    • Peel the cable and black sticker to reveal a hidden screw.
  8. Lenovo ThinkPad T480s Trackpad Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad T480s Trackpad Replacement: paso 8, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove four 2.3 mm screws.
  9. Lenovo ThinkPad T480s Trackpad Replacement: paso 9, imagen 1 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 9, imagen 2 de 3 Lenovo ThinkPad T480s Trackpad Replacement: paso 9, imagen 3 de 3
    • Open the bottom case and remove the trackpad.
    • The ribbon cable will slide through and out of the bottom of the case.
Conclusión
7 personas más completaron esta guía.
Sarah Westberg
Miembro Desde 03/11/19
29,462 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,533 Guías creadas
3 comentarios
Thanks! Worked.
Drew - Contestar
do you have a part number for the replacement trackpad?
Adam S - Contestar
Hi Adam S, I did a search by the touchpad SKU and a general search by the make and model of the laptop but it didn't come up. Have you tried contacting Lenovo? It's possible they might have the part number even if they don't sell the part, but then you might be able to find it on the secondary market. This might be a good place to start: https://pcsupport.lenovo.com/us/en/solut.... I hope this helps!
Sarah Westberg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 62
Ultimos 30 días: 213
Todo El Tiempo: 7,267
