Saltar al contenido principal
Lenovo Legion Y7000P RAM Replacement
Spencer Day
Spencer Day y otro contribuidor
Última actualización: March 18, 2024
20 - 30 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace or upgrade the RAM in your Lenovo Legion Y7000P laptop.
This laptop has two slots for DDR4 2666 MHz memory.
  1. Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: paso 1, imagen 1 de 2 Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: paso 1, imagen 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo Legion Y7000P RAM Replacement, Flip your laptop over: paso 2, imagen 1 de 1
    • Flip your laptop over so the rubber feet are facing up.
  3. Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: paso 3, imagen 1 de 2 Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: paso 3, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  4. Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: paso 4, imagen 1 de 2 Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: paso 4, imagen 2 de 2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  5. Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: paso 5, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: paso 5, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: paso 5, imagen 3 de 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Lenovo Legion Y7000P RAM Replacement: paso 6, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement: paso 6, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement: paso 6, imagen 3 de 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Lenovo Legion Y7000P RAM Replacement, Remove the back cover: paso 7, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the back cover: paso 7, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the back cover: paso 7, imagen 3 de 3
    • Remove the back cover.
  8. Lenovo Legion Y7000P RAM Replacement, Reassembly information: paso 8, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Reassembly information: paso 8, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Reassembly information: paso 8, imagen 3 de 3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
  9. Lenovo Legion Y7000P RAM Replacement, Heat the black cover: paso 9, imagen 1 de 2 Lenovo Legion Y7000P RAM Replacement, Heat the black cover: paso 9, imagen 2 de 2
    • A stiff, black cover runs across the heatsink and fans.
    • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
    • Heat an iOpener and apply it to the cover for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  10. Lenovo Legion Y7000P RAM Replacement, Remove the cover: paso 10, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the cover: paso 10, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the cover: paso 10, imagen 3 de 3
    • Gently peel up and remove the black cover.
    • During reassembly, press the cover back into place using the residual adhesive.
  11. Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: paso 11, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: paso 11, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: paso 11, imagen 3 de 3
    • Use the flat end of a spudger to push the battery connector straight out of its socket.
    • Push the tab on top of the battery connector, not the wires themselves.
  12. Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: paso 12, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: paso 12, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: paso 12, imagen 3 de 3
    • A metal shield covers the sticks of RAM.
    • Use a spudger to pry up the left side of the metal shield.
  13. Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: paso 13, imagen 1 de 2 Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: paso 13, imagen 2 de 2
    • Remove the metal shield.
    • During reassembly, align the shield with its metal clips and press down firmly around the perimeter to secure the shield.
  14. Lenovo Legion Y7000P RAM Replacement, Remove the RAM: paso 14, imagen 1 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the RAM: paso 14, imagen 2 de 3 Lenovo Legion Y7000P RAM Replacement, Remove the RAM: paso 14, imagen 3 de 3
    • Two metal arms secure each stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • Repeat the process to remove the other stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
Conclusión
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
Miembro Desde 09/14/22
95,712 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,548 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 45
Ultimos 30 días: 336
Todo El Tiempo: 726
