Huawei Watch GT 2e Motherboard Replacement
Introducción
Ir al paso 1Use this guide to replace a damaged motherboard in your Huawei Watch GT2e.
Qué necesitas
Turn off the watch:
Press and hold the top button for >3 sec.
Tap "Power off".
Push the small sliding nub on one of the watch band pins inwards toward the center of the watch band.
While holding the nub in, pull one side of the pin out of its recess on the watch housing, then the other side.
Remove the band.
Repeat this process to remove the second band.
Remove the four 3.5 mm-long T3 Torx screws on the back of the watch.
Place the point of a spudger in the small hole on the side of the rear case.
Use the spudger to push the rear case away from the housing to create a small gap. Use steady force to separate the two parts.
Flip the rear case assembly open towards the buttons to access the interconnect flex cable connector.
Herramienta utilizada en este paso:Tweezers$3.99
Remove the 2.5 mm-long Phillips screw securing the interconnect cable bracket.
Use a pair of tweezers to slide the interconnect cable bracket down and left to unlatch it.
Remove the interconnect cable bracket.
Use the flat end of a spudger to pry up and unplug the interconnect cable.
Remove the rear case assembly.
Use the point of a spudger to slide the bottom part of the display connector bracket towards the buttons to disengage its latch.
Herramienta utilizada en este paso:Tweezers$4.99
Grab the bottom part of the bracket with a pair of tweezers and lift it up and out of its top latch.
Remove the bracket.
Remove the four 2.5 mm-long Phillips screws from the motherboard.
Check that the button cables are not obstructing the motherboard.
If necessary, gently press the cables toward the buttons to bend them out of the way with a pair of tweezers or a spudger.
Use a pair of tweezers to grab the part of the motherboard closest to the buttons.
Lift up that side of the motherboard first to free it from underneath the case on the opposite side.
Remove the motherboard.
If possible, turn on your device and test your repair before resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
4 personas más completaron esta guía.
