Saltar al contenido principal
How to Tighten Your Samsung Refrigerator Door Handles
Qué necesitas
  1. How to Tighten Your Samsung Refrigerator Door Handles, Tighten the door handle: paso 1, imagen 1 de 1
    • Follow this step to tighten a loose door handle.
    • Use a hex driver to tighten the set screw securing the door handle to the refrigerator.
    • The set screw is normally near the end of the handle where it connects to the refrigerator.
    • This screw is commonly 2.5 mm hex size, but may vary depending on the refrigerator.
  2. How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: paso 2, imagen 1 de 3 How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: paso 2, imagen 2 de 3 How to Tighten Your Samsung Refrigerator Door Handles, Remove the door handle: paso 2, imagen 3 de 3
    • Follow this step if you want to remove or replace the door handle.
    • Use a hex driver to remove the set screw securing the door handle to the refrigerator.
    • Lift the handle off of the screw post and remove it.
Conclusión
Arthur Shi
Miembro Desde 01/03/18
237,698 Reputación
474 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
16,239 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 51
Ultimos 30 días: 222
Todo El Tiempo: 639
