Saltar al contenido principal
HP Envy Sleekbook m6-k010dx Keyboard Replacement
codi whittaker
codi whittaker y 3 otros contribuidores
Última actualización: June 18, 2018
20 - 25 minutos
Moderado
Introducción
Ir al paso 1
This device guide aims to replace a non-functioning HP Envy Sleekbook m6-k0101x keyboard. This guide should only be used if none of these troubleshooting ideas provide any desirable results. Before dismantling your device, ensure that your workspace is free from any open liquids or spare objects that might hinder this process.
Qué necesitas
Herramientas
  1. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 2, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 5, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 5, imagen 2 de 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Fan: paso 6, imagen 1 de 1
    • Remove two 3mm Phillips #00 screws from the fan.
  7. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 7, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  8. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 8, imagen 1 de 1
    • Lift the fan upwards to remove it from the computer.
  9. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Keyboard: paso 9, imagen 1 de 1
    • Flip up the black tab on the ZIF connector and pull the blue and white flex cable connecting the touchpad to the motherboard.
  10. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 10, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 10, imagen 2 de 2
    • Remove three 3mm Phillips #00 screws from the SD card board.
    • Remove the SD card board.
  11. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 11, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 11, imagen 2 de 2
    • In order to remove the RAM, pull each silver clip (one at a time) away from the RAM.
    • The RAM chip should pop up. Gently remove the RAM from the motherboard.
  12. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 12, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 12, imagen 2 de 2
    • Remove four 3mm Phillips #00 screws from the heatsink.
    • Lift the heat sink out from the device and set it aside.
  13. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 13, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 13, imagen 2 de 2
    • Remove the black and white antenna wires from the Wi-Fi card.
  14. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 14, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 14, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 14, imagen 3 de 3
    • Remove the two 3mm Phillips #00 screws that secure the speaker to the device.
    • Remove the four 4mm Phillips #00 screws from the bracket.
    • Locate the speaker cable connecting the speaker to the audio board. Gently tug on this cable to dislodge. Set the speaker aside.
  15. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 15, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 15, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 15, imagen 3 de 3
    • Remove the two 3mm Phillips #00 screws that secure the RJ-45 module.
    • Lift the white tab on the ZIF connector and pull the ribbon cable out.
  16. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 16, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 16, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 16, imagen 3 de 3
    • Remove the 3mm Phillips #00 screw connecting the chip to the housing.
    • Lift up silver bracket.
    • Lift up the white flap on the ZIF connector and remove the purple ribbon cable.
  17. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 17, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 17, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 17, imagen 3 de 3
    • Remove the cover for the RM-45 port.
    • Gently lift and remove the chip from its housing.
  18. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 18, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 18, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 18, imagen 3 de 3
    • Remove the 4mm Phillips #00 screws.
    • Remove the silver 3mm Phillips 3 mm screw.
    • Lift all three black flaps in the ZIF connectors and remove the attached ribbon cables.
  19. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 19, imagen 1 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 19, imagen 2 de 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 19, imagen 3 de 3
    • Use your hand and gently remove the connector to the back up battery for the motherboard.
    • Remove the four 4mm Phillips #00 screws from the motherboard.
    • Lift the board at an angle and pull outwards to dislodge it from the device.
  20. HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 20, imagen 1 de 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: paso 20, imagen 2 de 2
    • Remove the thirteen silver 3mm Phillips #00 screws that secure the keyboard to the frame.
    • Lift up the keyboard from the bracket and pull outwards to remove the keyboard from the device.
Conclusión
2 personas más completaron esta guía.
codi whittaker
Miembro Desde 02/14/18
508 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G4, Nance Spring 2018 Miembro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
Miembros de 4
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 14
Ultimos 30 días: 25
Todo El Tiempo: 1,976
