Saltar al contenido principal
Dell XPS 15 9530 Battery Replacement
Larissa Omura
Larissa Omura y 4 otros contribuidores
Última actualización: May 17, 2024
10 - 20 minutos
Moderado
Introducción
Ir al paso 1
Removal of the battery will be covered in this guide. Be careful disconnecting cables as to not break them or their connectors.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Herramientas
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Ver más…
  1. Dell XPS 15 9530 Battery Replacement, Base Cover: paso 1, imagen 1 de 3 Dell XPS 15 9530 Battery Replacement, Base Cover: paso 1, imagen 2 de 3 Dell XPS 15 9530 Battery Replacement, Base Cover: paso 1, imagen 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Battery Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9530 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Battery Replacement: paso 3, imagen 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Battery Replacement, Battery: paso 4, imagen 1 de 2 Dell XPS 15 9530 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Battery Replacement: paso 6, imagen 1 de 1
    • Lift the battery off the chassis.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 12
Ultimos 30 días: 48
Todo El Tiempo: 4,021
