Saltar al contenido principal
Canon PowerShot G12 Battery Replacement
Nathan Meuwissen
Nathan Meuwissen y 2 otros contribuidores
Última actualización: February 27, 2024
5 minuto
Muy fácil
Introducción
Ir al paso 1
Replacing the battery is very simple and relatively non-invasive. If the battery has sustained corrosion or is simply not charging, replacement becomes necessary.
In this guide, you will learn how to replace the battery which is responsible for powering the camera.
  1. Canon PowerShot G12 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera over with the bottom facing toward you.
    • Place your thumb on the compartment labeled "card/batt open" and slide it outward and up, exposing the battery.
  2. Canon PowerShot G12 Battery Replacement: paso 2, imagen 1 de 1
    • Push out the red latch to release the lock.
    • Remove the battery.
    • Note the battery's position in the terminal.
  3. Canon PowerShot G12 Battery Replacement: paso 3, imagen 1 de 1
    • To insert a new battery, push the red latch out.
    • Insert the battery into the terminal, ensuring the positive end marked with a red arrow is facing downward.
Conclusión
Equipo
USF Tampa, Team 1-5, Leahy Winter 2015 Miembro de USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 1,428
