Saltar al contenido principal
ASUS G73JH-BST7 Battery Replacement
Deven Rodgers
Deven Rodgers y 5 otros contribuidores
Última actualización: January 5, 2021
2 minuto
Muy fácil
Introducción
Ir al paso 1
If your ASUS G73JH-BST7, or ASUS G73 Gaming Series Laptop can no longer hold a charge, it likely requires a battery replacement. By using your device frequently, the battery life can deplete overtime.
Swollen batteries can be extremely dangerous but can also cause damage to your ASUS. Take caution  when removing the battery if you suspect this.
Be sure to turn off your device and begin the replacement.
  1. ASUS G73JH-BST7 Battery Replacement, Battery: paso 1, imagen 1 de 2 ASUS G73JH-BST7 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 Battery Replacement: paso 2, imagen 1 de 3 ASUS G73JH-BST7 Battery Replacement: paso 2, imagen 2 de 3 ASUS G73JH-BST7 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 Battery Replacement: paso 3, imagen 1 de 3 ASUS G73JH-BST7 Battery Replacement: paso 3, imagen 2 de 3 ASUS G73JH-BST7 Battery Replacement: paso 3, imagen 3 de 3
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
Conclusión
Deven Rodgers
Miembro Desde 10/23/18
253 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 528
