Saltar al contenido principal
Índice
Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
If your Lenovo ThinkPad T570 will not charge when plugged in, follow this troubleshooting guide.
Broken Charger
  • Clean the charger of dust and debris.
  • Check for any visible damage.
  • Ensure it is the correct charger (USB-C).
  • Try unplugging and plugging it back in.
  • If possible try different chargers and power outlets.
If these steps do not resolve the issue, the charger may be broken and will need to be replaced.
Failed Battery
  • Make sure the battery is properly attached. This is located on the bottom of the laptop next to the hinge mechanism. Position the laptop so the battery is located at the top.
  • You will see two switches on either side of the battery. Ensure that the left switch is positioned to the left. Switch and hold the switch on the right while sliding the battery away from the device.
  • Reinsert the battery by sliding it back into its original position until you hear a clicking noise.
If these steps do not resolve the issue, the battery may be faulty and will need to be replaced. Replacement parts can be found on various online sites such as Amazon.
Incorrect Power Management Settings
  • Ensure that “power saving mode is turned off by opening the settings and clicking system
  • Click Power and battery
  • Click Battery saver
  • If the Battery saver is on, click Turn Off Now
Wyatt Kirschner
Miembro Desde 09/04/24
124 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 125
