My air conditioner is not working
Why is my air conditioner not working
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
Generally the first thing to check is the refrigerant pressure, the best way is to test it is via an OBD tool, the second thing is the AC clutch that engages the compressor, you can hear it when you turn on the AC but it works only if the there's a refrigerant to begin with.
So check if you have enough pressure inside the circuit.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 21
1. car not running
2. broken drive belt
3. bad clutch
4. broken wiring
5. bad switch
6. refrigerant leaked out
7. air director not working or stuck
8. bad compressor
9. plugged up refrigerant lines
You need to see an HVAC mechanic.
- de bill
