Saltar al contenido principal
¿Por que mi portatil acer no enciende
El portatil no enciende, no reconoce el cargador de corriente
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@fredycarva11376 start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery (if it is removable). Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Let us know what you find out by doing this.
Since iFixit does not yet have a specific guide for your computer, use something like this video
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@fredycarva11376 empieza por lo fácil. Desconecta la alimentación del ordenador desenchufando el cable de alimentación del ordenador. Desconecta todos los dispositivos externos del ordenador. Retira la batería (si es extraíble). Ahora mantén pulsado el botón de encendido durante unos 30seg-1min. Vuelve a conectar el adaptador de corriente alterna y comprueba si el ordenador da señales de vida.
A continuación, comprueba la fuente de alimentación. Asegúrate de que tiene los voltajes adecuados. Comprueba que los conectores no estén doblados, etc. Comprueba la toma de entrada de CC de tu portátil. Asegúrate de que no hay corrosión, residuos, etc. que impidan que funcione. Límpialo de cualquier resto, etc., utiliza unas bocanadas de aire para limpiarlo. Si nada de esto funciona, coge un amperímetro y comprueba si tu portátil consume algún amperaje del cargador. Después, comprueba si la placa base recibe alimentación. Para eso, por supuesto, tienes que abrirla. Publica unas buenas fotos de lo que veas. Así podremos ver lo que tú ves.
También es posible que se trate de un módulo RAM defectuoso o de una pantalla LCD defectuosa. Así que quita la RAM, limpia los contactos con una goma de borrar. Hazlo con cuidado para no destruir el módulo. Sustitúyelo y reinicia. Si tienes más de un módulo, quítalo y deja sólo uno conectado.
Cuéntanos lo que averigües haciendo esto.
Como iFixit aún no tiene una guía específica para tu ordenador, utiliza algo como este vídeo.
Mientras trabajas en tu portátil, haz muchas fotos. Una vez que hayas terminado con él, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga un dispositivo con los mismos problemas que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
fredy carvajal tuberquia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 21
