Saltar al contenido principal
Cámara de 7,1 megapíxeles de Canon, modelo SD750.
Preguntas 9 Ver todo
new battery but screen black
when i turn the camera on the lens comes out but the screen stays black brand new battery fully charged
Es esta una buena pregunta?
Puntuación 0
1 comentario
Black screen is caused by a defective high intensity LED strip in the display backlight unit. When these fail you need to replace the backlight assembly
- de
Agregar un comentario
1 Respuesta
Solución Elegida
ric, try to hold down the menu key, turning it on and off and resetting the menu options. "Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu. Press the down arrow five times to select "Reset All." Press the "Set" button. Press the right arrow button once to select "OK." Press "Set." from here.
If that does not work,check the flex connector on your LCD. Here is the guide for the LCD screen. You may have to replace the LCD. Hope this helps, good luck
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
ric estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 7,636
