Saltar al contenido principal
Guías de reparación para componentes informáticos, periféricos y accesorios.
Preguntas 183 Ver todo
PC Assembled, but no display
Put in cpu(Ryzen 5 5600x) into motherboard (asus prime b450 m ii) applied thermal paste and put on stock cooler, put in RAM (16gb 8x2) put in m.2 storage 1 tb. Put motherboard in case put in graphics card Rx 6600. Put in power supply and plugged in all the cables. Fans Spin when I turn it on but no display onto monitor. This is a problem, my friend is having, I am going over tomorrow to help, but honestly know nothing myself really... Anyone got any ideas, would be much appreciated :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I can't find an ASUS Prime B450M II mother board but there is an ASUS Prime B450M-A II which requires at least version 2409 BIOS update for the Ryzen 5 5600X CPU to work.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Troubleshooting new PC builds are and do deserve an entire book's worth of possibilities. Boiled down to the basics you are looking at a process of elimination to slowly verify and weed out each component that works until you find the one that isn't. I highly recommend looking through the many ifixit troubleshooting guides or simply googling one (youtube is silly with them if you hate reading).
The main information that will help you troubleshoot a preboot or prePOST issue is the onboard indicator on the motherboard. In your case this is likely just a buzzer/beeper that will emit coded tones to indicate which part of the boot up process has been reached or failed. Here is a link to the Asus default guide on this but you could/should also look up the specific ones for your motherboard and where/what the indicator is.
https://www.asus.com/us/support/FAQ/1029...
That being said if everything is working correctly and POSTing you could try using the alternate graphics outputs (HDMI instead of DP vis versa etc) in case the default output pre-driver install is not the one you have plugged in.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you so much, so kind to help with this! All the best to you :)
- de
Añadir tu respuesta
Caius estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 105
