Saltar al contenido principal
Séptima generación de iPad, lanzada el 25 de septiembre de 2019, disponible en modelos de 32 o 128 GB. Número de modelo A2197.
Preguntas 20 Ver todo
2019 iPad 7 Wifi A2197 does not power up
Hi,
My iPad A2197 fails to power up. Since having the CPU replaced (as suggested elsewhere) would cost more than buying another iPad, I've decided to have a go at repairing this myself and hopefully up my skill set at the same time. I figure it's better than chucking it straight in the bin.
With the aid of schematics and a component placement diagram, and using my probe, I've found that caps C8120-C8126, C8180 and C812F are shorting to ground. All caps are connected to PPVDD_S1_SOC. As it's unlikely that they've all failed, I'm wondering what could be causing this short.
Any suggestions as to what to do to further narrow down the problem? What additional information would you need me to provide? TIA!
Ted
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
EDIT: on further examination, it seems other caps elsewhere on the board which sit on PPVDD_S1_SOC also shorting to ground. At this point, I am starting to suspect it could be the infamous CPU connection issue although I really hope it isn't. Does anyone disagree?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There are a few things I would note in your situation.
  1. How do you know it's short to ground? What is the actual resistance you ground you're getting? Many if the power lines that go to the CPU are naturally low resistance so this may be a normal reading.
  2. When any component on an electrical line is bad it has an effect on the whole line. So one bad cap would cause any component on that line to read as short to ground. It's like punching a hole in a hose. Doesn't matter where else on the hose you poke, it's still going to be leaking water.
No power on these can be any number of things, but it sounds like you're on the right track.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Thanks for the advice. I was using diode tester mode to determine the shorts. I rechecked and resistance values are around 14.7 ohms. As per my additional comment, I've since found that the other components on PPVDD_S1_SOC (there aren't that many) are also going to ground. Do you reckon it could be the CPU?
- de
@ted78042 I happen to have an iPad 6 board at my immediate disposal that I know works, and I am also getting about 14 ohms on that line. As I said, I suspect that line is just a very low resistance line naturally. That's the case for many of the electrical lines that power the CPU (like this one).
For context.
PPVDD - Which is essentially noting a positive power supply voltage.
S1 - The power state. S1 is just below the device is fully on.
SOC - System on a Chip, the CPU.
It could be the CPU anyway, but I would probe around and see if you can find any other shorts, or anything that looks off. How did the device die?
- de
@flannelist I poked around some more and the tester bleeped for quite a lot of other caps but as you say, switching to resistance readings showed that those lines had very low resistance.
I've read elsewhere that this particular iPad model is known for having CPU contact problems and that reballing was the solution. However, I most definitely do not have the skills nor the tools to attempt something like that.
I've no idea how it came to die; it just failed to turn on one day. Quality control failure, I imagine. :-/
- de
Añadir tu respuesta
Ted estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 38
Todo El Tiempo: 372
