Saltar al contenido principal
Séptima generación de iPad, lanzada el 25 de septiembre de 2019, disponible en modelos de 32 o 128 GB. Número de modelo A2197.
Preguntas 20 Ver todo
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
Fue útil esta respuesta?
Puntuación 1
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
Puntuación -1
1 comentario:
@willjoe it’s not a touch issue it’s an image issue.
- de
Añadir tu respuesta
Oliver Byrne estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 342
