Saltar al contenido principal
The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
Preguntas 20 Ver todo
My bottom speaker is crackling
My bottom speaker is crackling the higher the volume the worse the crackling. I've cleaned it and used compressed air but, still nothing it has done it before but it went away or I stopped noticing it I do admit I've dropped and cracked the front and back but it still worked it all started when I turned the volume up one day for a song then it started but it does not do it for calls.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi
From my own experience when speakers start crackeling or making distorted sounds it tends to mean that they are failing and need replacing
These issues can come and go but they usually just need replaced to fix them once and for all!
Here’s a link to a replacement speaker
https://www.ebay.co.uk/itm/134000550806?...
Also here is a guide that should show you how to disassemble the phone then remove the speaker
https://m.youtube.com/watch?v=LhCX9eLQSI...
You only need to go up to the speaker part then perform what you just did on reverse to reassemble
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Trevor Dillon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 665
