Saltar al contenido principal
Lanzado en agosto de 2012, se identifica por su número de modelo M4700.
Preguntas 3 Ver todo
Need a specific spot picture to see what's missing
I got a dell m4700 from a friend but it doesn't work. He told me "I upgrade the ram and tried to change the thermal paste but I didn't know how to do it so I didn't and now it freezes on the dell logo" I replace the thermal paste and it still doesn't work but I found board damage so I would like to see someone's laptop to compare.
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Roberto4273 it will work a lot better if you post images of your board with your QUESTION. Let us see what is missing/damaged etc. Edit your QUESTION and use this guide to add images Agregar imágenes a una pregunta existente You also want to make sure that you give us any identification about your motherboard (not just the Make and model of your laptop but the actual board) just in case there are schematics for it etc. and from what I see it should be a Compal LA-7931P board Dell Precision M4700 LA 7931P Schematics
Dell Precision M4700 Motherboard Replacement
Update (09/18/2022)
Looks like you lost at least PQ503 which is a SSM3K7002FU_SC70-3D Mosfet. I suggest remove the board check for further damage and replace the transistor. It looks ( a bit hard to see) like all the solder pads are still there.
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Dell Precision M4700 Motherboard
Guía
Dificultad:
Moderado
30 - 45 minutes
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I added a better picture
- de
Añadir tu respuesta
Roberto4273 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 127
