Saltar al contenido principal
Reloj inteligente con rastreador GPS y reproductor de música en bluetooth
Preguntas 20 Ver todo
Adhesive to use to reassemble my Fitbit after battery replacement?
I am in the process of replacing the battery in my Fitbit Ionic but I don’t see adhesive listed under the parts or tools list, which is needed (and noted) for proper reassembly. Can someone recommend something similar to what Fitbit uses? I’m not going to use super glue in case I need to replace the screen battery again. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
typically you can use something like
Tesa 61395 Tape
or
Polyimide Tape
be sure to read the descriptions on them to see what would work better for you
good luck
Imagen de 108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.
Producto
Polyimide Tape
$9.99
Imagen de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Producto
Tesa 61395 Tape
$5.99
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Robert Simons estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 235
