Saltar al contenido principal
Información de reparación para HP EliteBook 2530p. Esta computadora portátil de 12,1" se lanzó a fines de 2008. Originalmente se envió con Windows XP o Vista cuando era nueva.
Preguntas 4 Ver todo
Laptop doesn`t turniej on
So it`s actually 2540p but it wasn`t an option, anyway, i know that the laptop is long past it`s lifetime but i`d really like to see how long it can go for. Long story short, the battery is long dead at this point and the laptop was working on AC only for the past few months, and today it just turned off during some a bit more intensive cpu task and won`t turn back on. With the battery in and power plugged in it does a short white and then constant orange blinks which afaik means low power onmaster battery. With the battery out and ac in, it gives a short white blink and goes quiet, then after pressing the power button it gives 8 orange blinks and then nothing. I`m honestly not sure what i can do at this point
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
A general statement:
Unless you are doing some thing like editing videos this machine is certainly not past it if you replace HDD with a SSD and increase RAM to the 8GB max.
Now to troubleshoot:
Service manual - http://h10032.www1.hp.com/ctg/Manual/c02...
  • Check the video cable from the main body to the hinged screen. Sometime the video will work if the screen is only partially open. Try this in different positions.
  • Remove battery and unplug and press power button to discharge any power left in system.
  • Open the bottom and blow out all dust. Dust can cause over heating.
  • Reseat the RAM modules.
  • Take out the CMOS “coin” battery.
  • Reassemble to see if screen comes on
That’s a start.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Andrzej Tubacki estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 674
