Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información sobre el dispositivo y la reparación del sistema de altavoces Behringer Eurolive B212D.
Why does my low frequency speaker have static noise?
Low frequency speaker has static but doesn’t sound blown, wondering what to replace to fix this issue.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Thank you! I will check and let you know the results!
- de
You're welcome and good luck! :-)
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If only statically during audio playback, check the internal speaker wires to see if loose connection, stray wires are causing the problem due to the vibrations of the speaker box. Also check your audio input cables to the unit. Do a visual inspection of any circuit boards for cold solder joints, cracked solder joints, overheated spots, bulging capacitors etc.
If static is present with no audio signal applied, then using a signal tracer or oscilloscope to trace through the speakers circuitry should be of assistance in tracking down the problem.
If static begins when hooking up your external PA devices (ie mixer, mics, mic cables etc) then they will also need to be checked one by one to eliminate them as a possible source.
The following may also be of use to you:
https://old.reddit.com/r/audiorepair/
Fue útil esta respuesta?
Puntuación 0
1 comentario:
- de
Añadir tu respuesta
Justin Burrell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 867
