Why my recent apps button is worked automatically?
If I will use my mobile phone for more than 10 minutes it became very heat and the recent apps button pressed automatically. It irritates me.
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
If your phone gets hot after only 10 minutes and seems to malfunction, then it may be infected with malware. Performing a full factory reset is a sure-fire way to remove malware from your phone. The reset can be done in your phone’s Settings.
Fue útil esta respuesta?
It doesn't work
“It doesn't work” is a bit vague, please be more descriptive because I can't see what you are seeing. You said that your phone starts to overheat and malfunction after 10 minutes. Are you unable to get into your phone's Settings before the 10 minutes are up?
Being able to reach the Settings app would really help fix the issue.
saya sudah melakukan di hp samsung j2 saya tapi masih seperti itu
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,144
