Saltar al contenido principal
La Canon PowerShot A2000 IS es una cámara de apuntar y disparar de 10 megapíxeles con un zoom óptico estabilizado de imagen de 6x. Fue lanzado originalmente en 2009.
Preguntas 9 Ver todo
What to do for locked card warning(any sd card
what do i do if my camera says card locked ,no matter what card I put in? I have checked the tab on the chip and it is'nt that.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Check that the card is seated properly inside the camera. It could also be possible that the memory card is damaged or defective, so try swapping in a different Secure Digital card. There is a little metal flap inside the card chamber that detects the lock position for the card. See if that is properly engaging. Sometimes you can re-position it with a paper clip etc. Here is a link to it http://camerarepair.blogspot.com/2009/07... Also, of course, check your user manual to make sure that it is not in the settings of your cam ;-) Good Luck
Fue útil esta respuesta?
Puntuación 2
1 comentario:
the second tip was very helpful you'r the first one guiding it after searching an hour for this problem thanks
- de
Hello!, I have the EXACT answer for you. I also own the same camera. Watch this for help:
https://www.bing.com/videos/search?q=unl...
I actually figured how to unlock my sd card before i watched the vid!
Puntuación 0
Añadir tu respuesta
valworley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 2,190
