Saltar al contenido principal
Home Button not working
I can't use the home button to get out of apps so I am stuck turning it off and on again manually. I have heard that taking it apart is very difficult to do and taking it to apple is expensive. I also tried the rubbing alcohol on the home button and it still didn't work!!! Is there anything I can do for my first generation iPod? It is a 2.2.1 version. Any ideas?
Es esta una buena pregunta?
Puntuación -1
1 comentario
bubbles, take a look at the guides on the top right under the photo..it would work better if you start your own question and then you'll get more help.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Check on this guide, look at the photo in step 17, and you will see a white disc in the bottom middle of the photo. That is the home button. Underneath the white disc is a gold ring. When the home button is pressed the disc pushes down and creates a circuit with the ring. I would gently pry of the white ring since it is only held in place by a weak glue lift it up and you will see a small metallic disc on the underside of the white disc. Clean both of those areas thoroughly with isopropyl alcohol.Then carefully align the white disc back over the gold ring and tape in place with just a small piece of sellotape. Hope this helps and good luck to you.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
BUBBLES3 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,993
