Saltar al contenido principal
Modelo A1318 / 32 o 64 GB de capacidad
Preguntas 20 Ver todo
What contacts should I clean with ISOPROPYL ALCOHOL?
I will explain what happened with my iPod Touch 3rd Gen.
After one year of use, one day the screen got weird, with white and black strips and some other colors. The iPod did NOT fell into water, the problem started with no apparent reason.
I tried to restart and restore later with no positive results.
After two days I turned it on and, for my surprise, the LCD worked 100%, with no more strips on it, but the digitizer had stopped working...
After some days, I decided to order a new digitizer from eBay (actually I bought two).
When arrived, I used the iFixIt guide to open and replace the digitizer.
RESULT: the first and second digitizer did NOT work.
After read some articles and reviewing some related questions at iFixIt, I saw that some guys were trying to clean the contacts using ISOPROPYL ALCOHOL.
So, my great question is: What contacts should I clean with ISOPROPYL ALCOHOL? All of them?
Hope you guys can assist me on it.
With best regards,
Leonardo Ramos.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Leonardo, if you clean contacts that means you have the iPod open. Personally, I would suggest you clean the whole logic board, front and back. Every connector,every cable end needs to be cleaned and inspected. Do not forget to look for ant corrosion on the underside of the board.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Leonardo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,217
