Saltar al contenido principal
El Satellite C660 es una serie de portátiles lanzados por Toshiba alrededor de 2010. Tienen pantallas de 15,6 pulgadas y una variedad de procesadores Intel.
Preguntas 30 Ver todo
Why is my laptop making sound like something is moving inside?
Hi,
It has been few weeks now that my laptop make weird sound inside. I open it because it wasn't turning on correctly and then I saw a piece of tape that wasn't on any component. Then I thought that piece of tape was making noise with the fan but now the computer turn on but stay with a black sceen with the underscore flashed and the noise is still there.
Any idea?
Thanks.
PS: Sorry for my english.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
What kind of sound?
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
The devices capable of producing some sound inside a normal laptop are the fan and the hard drive. When the fan is not attached properly, due to some screw or broken part, then there will be reasons for noise. In the case of the hard disk, this only makes a noise when tired.
Solutions:
- securely fasten the fan and make sure that all the connectors are secure;
- remove the hard drive and check if the noise continues;
- disconnect the fan connector and check if the noise continues;
Fue útil esta respuesta?
Puntuación 3
I also had strange noises coming from my laptop. It made crackling and swishing noises when I moved the laptop or when typing. Turned out it was because my microphone was constantly on and thus picking up all noises from inside laptop or something. As soon as I disabled the microphone it stopped. Not sure if you had the same problem, but someone out there might….
Puntuación 2
1 comentario:
Your advice is a life saver.
I disabled the microphone access and I didn't hear those squeaky noises !!
- de
don’t sit alone in the evening, demons have entered your laptop
Puntuación 1
my laptop is sound like tunder
Puntuación 0
Añadir tu respuesta
RICARD estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 36,813
