Saltar al contenido principal
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
Preguntas 20 Ver todo
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
This question was migrated from https://meta.ifixit.com/Answers.
- de
Agregar un comentario
2 Respuestas
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Air flow and throttle show a short circuit .wiring okay
- de
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Puntuación 0
Añadir tu respuesta
Stephen Ryan Bearden Madison E estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,435
