Saltar al contenido principal
Nissan introduced the sixth generation Sentra at the 2006 North American International Auto Show in January.
Preguntas 13 Ver todo
Stalling after tune up and changing mass air flow sensor
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Did you replace the MAF with a Nissan part, or an aftermarket one?
- de
Agregar un comentario
1 Respuesta
Did you scan your car prior to installing the MAF to make sure that was the actual problem? Or is it was a mechanic did you see the print out? Then after installing the part, did you clear the codes, test drive and check to see if new or same codes came back?
MAF sensors are very fragile, and can be easily damaged during install by being rougher than necessary.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Marcus Napoleoni estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 445
