Left high beam malfunction
My left high beam does not work on my 1996 Toyota Tacoma even with new lamp and relay. Solution?
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
@hannibal316 check the socket and see if you have power coming to it when you turn your Hi-beams on. If you lamp is new and the relay is new you are most likely having an issue with the socket/wiring.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 131
1 comentario
Thanks, will look into it☺
- de Hannibal
