Saltar al contenido principal
La Canon PowerShot S90 es una cámara digital compacta de 10,0 megapíxeles de gama alta anunciada originalmente en 2009.
Preguntas 6 Ver todo
Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
- de
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
- de
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
- de
Yes I checked the door and it made contact but I was never able to get the camera working
- de
Añadir tu respuesta
Ned Hascall estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 999
