Saltar al contenido principal
This model was released years ago and continues to be produced. The disassembling is straightforward as long as you follow the instructions.
Preguntas 8 Ver todo
How do I take off the rubber grip.
I see how the hands pictured in all the guides for the dis-assembly of the Wahl Li Trimmer, but I don't know what to do with them. I realize this is very basic, but I need to know each step of the dis-assembly process.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
I just figured out a way to take off the grip sleeve. First point is that the picture of the hand in the front was misleading! There is a thin gap between the head and the grip sleeve. I turned the trimmer so the back faced me. Stuck my fingernail into the gap, then slid it under the Rubber Grip Sleeve. Then pulled the sleeve up off the handle and down toward the bottom to create a flap my fingers could grab. After that I gently slid one hand to the front side so fingers were able to replicate the hand at the back. I pulled down gently keeping in mind the switch in the front.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
P.I. Mort estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 202
