Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El mouse Logitech Performance MX es un mouse de primer nivel de Logitech con tecnología de seguimiento de campo oscuro y una rueda de desplazamiento de giro libre. Lanzado en 2009. Número de modelo: 910-001105.
Mouse wheel rubber replacement
The rubber on the scroll wheel is somewhat loosen up on my Logitech Performance MX. This renders the wheel to operate without the frictionless scrolling. How to tighten or replace this rubber
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Exceedingly common problem that happens very quickly with this mouse. The rubber loosens, and the slack gets caught in the gearing.
Just cutting it off seems to be the only solution, though with some trial and error you might find a rubber o-ring that fits it.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Just cut it off, why didn't I think of that? Took it apart and everything, couldn't think to just cut it off. Works perfect now. Thanks bro!
- de
I use silicone rings the kind for women's jewelry, for replacing the rubber. They're for people with metal allergies. Just figure out what size your wheel equates to in ring sizes and get a size down so the ring fits snug around the wheel and won't slip around. I stick to thinner women's sizes cause the regular ones are usually too thick. I ordered a bunch of different thickness/widths from amazon to see which ones worked for my mouse then returned whatever didn't fit.
- de
I will apply this idea to fix my Logitech VX Nano.
https://youtu.be/uHgs8B_6c7I
Puntuación 0
Watch this video: https://www.youtube.com/watch?v=hxhF5F5F...
Puntuación 0
Añadir tu respuesta
Mohd Razwan Rusli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 8,733
