Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Hard Drive Failure after Battery replacement
Hello Fellow Techncians
I was wondering if you could help me
I have replaced a battery in a ipod 4th gen with Click wheel, as with all repairs, i very carefully opened it up and removed the hard drive and placed it in a safe place, there was no bumps knocks etc
After replacing the battery and powering it up i get the dreaded folder icon with the exclamation mark
i have tried reseating the hard drive multiple times and i have also tried putting it into disk mode. it gets into disk mode but when i plug it into a PC (i am not using a fire wire cable just a standard ipad 2 cable) it resets and i get the sad face icon
im perplexed as the hard drive was fine before now there is no activity
also when the apple logo comes on there is no back light
Please can you help
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You will want to carefully inspect the flex connecting the HDD to the logic board. Use this guide.
It may have been damaged or torn when you disconnected the battery. I would also look closely at the connectors on either end. Depending on what is damaged, it may be repairable although it wold likely require a micro-soldering repair. However, if the HDD is at fault, they can only be found "used" and are very expensive.
I recently upgraded a Classic 7th Gen to 256GB flash memory and it was really easy. I have never tried on a 4G but here is a link that may be of interest.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Ali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 312
