Saltar al contenido principal
La Nikon COOLPIX S9700 es una de las muchas cámaras de la serie COOLPIX de Nikon. Cuenta con un zoom óptico de 30x y una resolución de 1080p en un cuerpo delgado y compacto.
Preguntas 16 Ver todo
How do I remove the lens
I have a mark on the inside of the lens of my S9700. I almost looks like a chip, but I'm hoping not, and can't see how that could have occured. I know how to remove the outer most cover by twisting to the left with the lens extended, and can see that the lens glass itself is suspended by the rest of the structure. There are 3 screws which seem to be holding this assembly in place, but having removed them I still can't lift off the lens structure easily, and I don't want to force it too hard in case there is something more I have missed. Any help would be appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@davidsain , David, Posted a couple links below, I think if you posted at first link the owner may have a break down of lens he might send you, 2nd link are a few lens break downs/schematics that you can click on and check out the info. Good luck.
http://www.johncaz.net/blog/how-to-locat...
https://www.google.ca/search?q=Nikon+Coo...
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
David Plant estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,075
