Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Preguntas 20 Ver todo
Replacing Hard drive iPod Classic 60 Gb
iPod Classic 60Gb Model A1099
If I replace the hard drive in my 60Gb iPod Classic with a 240GB Toshiba MK2431GAH hard drive, do I follow the same directions as the standard hard drive replacement?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Do you have the fat or thin drive?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
That drive should work. Here's how to do it:
Reemplazo del disco duro del iPod 4ª Generación o iPod Photo
Here's how to do it: https://www.youtube.com/watch?v=dYZqTvlT...
Fue útil esta respuesta?
Puntuación 3
Yes-as long as it's the same connection (which it is), it will work. But if you haven't bought that drive already, I recommend this: https://www.amazon.com/Samsung-850-EVO-I... + https://www.amazon.com/SMAKN-mSATA-PCI-E...
Puntuación 2
1 comentario:
This drive solution is far cheaper and reliable than that HDD.
- de
Yes, assuming the connector is the same on both hard drives, and that it is compatible with the iPod (some of them have a limit as to how much memory they can see).
You might also consider replacing the HDD with an SD card, I've done this myself recently and it makes a noticeable difference. This is the shop I bought the kit from:
https://www.iflash.xyz/store/
Puntuación 1
Añadir tu respuesta
macdale4 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,066
