Latches for battery door
How can I replace latches for battery door on camera?
Update (01/05/2017)
How can I fix latches on battery door? Nikon Coolpix L20 Camera not used a lot & like new but latches broke.
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
@lje you will have to replace the battery cover. This guide will show you how to split the camera to get to it Here is how to remove the door from the housing.
the door itself is available at places like this and others.
Fue útil esta respuesta?
@lje , Linda, Use the links below to see how to fix/replace your battery door on your Coolpix, video is not your exact model, I do believe the battery door is the same. If not comfortable doing repair, have a good camera shop have a look and estimate repair. Good luck.
Where i can get this Nikon coolpix battery cover L 20
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 52
Todo El Tiempo: 3,487
