Saltar al contenido principal
Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
Preguntas 9 Ver todo
Phone will or load pass beginning screen
My phone locked up on me, so I took the battery out. When I turned the phone back on it now won't load pass the beginning LG screen. How can I get it back on?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Try holding the power button and the volume down button . when you get the android use the volume buttons to scroll up or down and select boot normally then press the power button to select . This should allow the phone to boot normally. If this gives no joy then try resettng the phone to factory settings . Please understand that you will loose all data you have on the phone , contacts, photos ,music, apps will all be gone . It will be the same as when you first got the phone. Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Susan Sells estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 74
