Saltar al contenido principal
Cámara de 14 megapíxeles. Tiene zoom óptico de 12x, zoom digital de 48x, OIS, video HD con micrófonos estéreo y enfoque automático. Viene en rojo o negro. Esta cámara es compatible con las siguientes tarjetas de memoria: SD/SDHC/SDXC/EyeFi (soporte completo).
Preguntas 17 Ver todo
Lens cover won't open anymore
My lens cover won't seem to open and close like it used to. This prevents me from taking pictures quickly because I always have to check to see if the lens cover is open, or not. I can force it open by hand, but wonder what I need to do to fix this problem?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Mine does the same, but it doesn't seem like it's the springs since when I turn off the camera, the lens cover closes by itself.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
It sounds like the springs in your lens cover may be out. If the lens stay open after you force them open, and don't bounce back into place, then it's most likely that your springs are broken or disconnected from the lens. You'll have to open up your camera to make sure! You may either have to replace the springs or simply reattach them to the lens cover.
Please see the troubleshooting page for more information.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Sam Blanton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 2,464
