Saltar al contenido principal
El Inspiron 15-3521 tiene una función de pantalla táctil opcional y tiene una pantalla de 15,6". Este portátil también se completa con un acabado mate y un teclado completo con teclado numérico.
Preguntas 20 Ver todo
unable to turn it on
i have a problem with my laptop "dell inspiron 3521" when i press on power button nothing is happening there is no response , and when i connect the adapter , the led of the adapter starts to blink and stops when i disconnect the adapter from the laptop
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Waleed Hamdy have you checked teh output of your AC adapter? Is it the right voltage for your Dell? what else have you tried? How long has this been going on?
- de
since yesterday my laptop is not working it happened suddenly , i think the adapter is working well as i have tried another adapter and it had made the same blinking on connecting it to the laptop
- de
Try to remove the battery, the AC adapter and tyour RAM memory. Then push and hold down the power button. Do so for a few minutes. Then replace the battery and one memory module as well as the AC adpater and see if it shows anything.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Waleed, As oldturkey suggest try a reset. From post in another forum I read, possible it could be a faulty/worn out battery. Check link below. Hope it helps, Good luck.
http://www.geekstogo.com/forum/topic/340...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Waleed Hamdy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 168
