Saltar al contenido principal
Lanzamiento 2016, enero, identificado por el número de modelo K430T. El tipo de pantalla es la pantalla táctil capacitiva IPS LCD, 16M colores y una cámara de 13 megapíxeles.
Preguntas 20 Ver todo
Power button failing when in the dark?
Just got a LG K10, for some reason if I'm in a dark area the power button/volume buttons become unresponsive. This issue does not exist in well lit environments. Anyone else experiencing this, or does anyone know why this might happen?
Es esta una buena pregunta?
Puntuación 0
1 comentario
I started having this issue ever since I got my screen replaced. I think it's some kind of hardware issue. If I'm in the dark and this happens it's because I have the brightness all the way up. When the brightness is on 0% and I'm in the dark I don't have this issue. So try lowering your brightness. Glad I'm not the only one with this issue
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Performed a factory reset last night, this did not resolve this issue. I will say though I did a little more trouble shooting and I might have figured it out.
I recently put a protective case on the phone that has a tempered glass screen protector. It could be that the tempered glass is somehow triggering the proximity sensor, making the phone think it's next to someone's head. Then with that sensor tripped and little to no light detected the phone thinks it's best to not turn of the screen.
Fue útil esta respuesta?
Puntuación 2
The light sensors may trigger your device .
So the best solution for you before you do anything else,is to factory reset your phone
Puntuación 0
1 comentario:
So ,you have figured it out .Great ,happy for you :D
- de
I have the same issue.. Im reading up on this... has to do with the tempered glass everybody recommends remove the tempered glass find a tempered glass with cut out for the sensor by the camera
Puntuación 0
This is bs my screen just blackens when the proximity cencor is covered where do i trun this shot of?
Puntuación 0
When in the dark area my phone swicth fail to come
Puntuación 0
Añadir tu respuesta
Gage estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 2,628
