Saltar al contenido principal
Modelo A1419 / Finales de 2012 / Core i5 de 2,9 y 3,2 GHz o Procesador Core i7 de 3,4 GHz, ID iMac13,2
Preguntas 20 Ver todo
4sns 1 c0000008 tl0p 124
Hi I am getting 4sns 1 c0000008 tl0p 124 hard test error. The CPU usage over 400%
Update (08/24/2016)
I have changed the hard drive and bought owc cable + sensor as u adviced
Update (08/24/2016)
ok thanks a lot Mayer jan ( SSD upgrade and kernel_task )
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Did you change the hard drive?
- de
I thought I recognized you. Let's delete this question and go back to the original. There was a months lapse between what I advised and your response and I missed it.
- de
Agregar un comentario
4 Respuestas
Solución Elegida
The problem was with the LCD sensor, no hdd sensor need for kernel_task problem. The HDD sensor is only for fans.
Fue útil esta respuesta?
Puntuación 0
Is the fan running fast and making very loud. If so, you make to reorient a wire. It is either a heat senser or fan sensor wire.I don't remember the exact name. It has white dot on the conector. You need to turn it 180* from how it was before installed your new hard drive. Infix it has a very good guide that explains it.
Puntuación 0
There is a sensor cable on some iMac models that must be attached to the replacement HDD for the fans to operate normally. I do not recall if the particular models include your mid-2010 iMac but the symptom you describe would be consistent with this requirement.
If you did not buy it from OWC / MacSales or other well-known Apple supporter, it is unlikely to have the required hardware.
Check with OWC to determine the correct replacement you require.
It's an issue in your lower slot
Puntuación 0
Has anybody solved this mysterie ??
I have the same behaviour:
And a kernel tast taking 300% CPU load
Puntuación 0
1 comentario:
You may find using this app will help in locating which sensor is failing: TG Pro See what it shows you.
- de
Añadir tu respuesta
Vardan Hovsepyan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,096
