Saltar al contenido principal
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Preguntas 20 Ver todo
Why is my phone not turning on?
My phone will not turn on or charge when plugged in it does nothing at all.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 9
2 comentarios
Charge your mobile battery with Universal Mobile Cell Phone Battery Charger. Then restart your phone. http://www.vidmateappsforpc.com/
- de
I have tried charging the battery with universal charger and I even bought a new battery but still not turning on
- de
Agregar un comentario
12 Respuestas
Respuesta Más Útil
While plugged into the charger hold down power/volume up and down buttons for 10 sec. See if this works. If not take to local carrier to try a new battery.
Fue útil esta respuesta?
Puntuación 5
1 comentario:
Works perfect, Thought I was going to have to get another phone. Thank you!!
- de
Hello, Since Th G3 model LG has had a bad issue with the phone bricking itself. THIS IS NOT A BATTERY ISSUE. Im a Technician Here in California. http://www.lg.com/common to contact them about issues. this also is the same with the LG G3,G4, and V10 boot loop issues.
Puntuación 3
3 comentarios:
i have boot issues with my lg v10 , do you know if there is any way to fix it because my phone is out of warranty
- de
My LG V10 just went off. And it's can't turn on again.
- de
To answer Diego's question, if the issue is the common boot-loop issue, then fixing it requires some level of skill, as the solution to the problem is reflowing the solder on the SoC or, if you have the skill and supplies required, reballing the SoC. To prevent the problem resurfacing, replace the stock thermal pad with a high quality thermal pad or paste, since the stock one doesn't do a good enough job of transferring heat from the SoC
- de
Keep an eye on this lawsuit.
http://www.androidauthority.com/lg-bootl...
Puntuación 1
hi my phone is not turning on lg v10
Puntuación 0
I have problem with my LG V10 bootloop problem
Puntuación 0
i also face this problum...
i've visited most of the best repairer but most of them tel me that it is an compney eror..
one of them repair my fone as wel.. my sel was start working but only for one day...
this problum could never be solved...
Puntuación 0
From what I gather, the LG models after the G3 have had an issue with the capacitors not being able to sustain a charge after some months of use. This may be a result in letting the phone die over and over again. Once it boot loops once, or won't power on, give up on it. Take it to LG within the 1st year of purchase (if applicable). If you bought it more than a year ago without insurance, you're out of luck.
Puntuación 0
1 comentario:
No, the problem with the V10 is that the CPU overheats and cracks the solder balls on the SoC
Source: personal experience involving multiple hours of online research and a semi-successful repair (did a reflow, but didn't heat the solder long enough so I ended up with a cold joint, redoing it after work today)
- de
my phone not turning on with the charger on and off the the charger
Puntuación 0
it will charge but will not turn on
Puntuación 0
1 comentario:
Yes,it will charge but it won't turn on.
Lg phones are not suitable for routine use.
- de
LG V10 no open mobile
Puntuación 0
3 comentarios:
LG mobile not good
- de
LG company not good
- de
LG V10 not open mobile
- de
Is this “press and hold volume and power for 10 seconds” solution for OLDER model V10s?
I have two LG v10 phones, and this solution doesn’t work on either one.
(One phone won’t turn on—the other is frozen on the logo screen! Talk about a one-two punch!)
Puntuación 0
My LG V10 they don't turn ON i press power my phone become a HOT not ON,why..??
Puntuación 0
1 comentario:
My LG phone dsnt turn on,if i press power only hot not on,why ?
- de
Añadir tu respuesta
Imani Monique estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 26,568
