Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
Lanzado en 2008, tiene un conector de 30 pines (se puede usar con iPhone 4S y modelos anteriores) que no funcionará con los modelos más nuevos. Las principales diferencias entre este modelo y la primera edición son el diseño y el color de los controles remotos.
Why the green light is permanent?
Hi, my Bose SoundDock Portable v2 has the green light permanent, and a i can´t use it. I can´t turn up the volume or turn down, and don´t reproduces the music.
Es esta una buena pregunta?
Puntuación 0
1 comentario
It worked like a charm !! Thanks !
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Is this with both the buttons on the device and the remote?
Fue útil esta respuesta?
Puntuación 3
13 comentarios:
No, when i press the buttons on the device or the remote, my bose doesn't make anything, the green light stay permanent
- de
I'm certain you've tried unplugging it and waiting a while before you use it again. Also I'm wondering if it works while its plugged in. It could be a faulty battery, for which you could Bose SoundDock Portable v2 Battery Replacement replace the battery
- de
i have the same problem with my bose soundock series ii, the bose sevice center told me that it need to replace the sound processor module but very expensive so i try to repair it myself, i found out that the crystal oscillator 16.974mhz is not working properly, tried to replace it but no luck, so i solder a 22pf capacitor to one pin of crystal to ground, now its working.
- de
Hey Marvin, you didn;t happen to take a photo of your completed fix? Thanks,
- de
Hello Marvin can you please attached the photos so it will be easy to fix the issue mine have same problem please help
- de
Mostrar 8 comentarios más
This is the fix you need
Puntuación 1
4 comentarios:
22pf ceramic capacitor
- de
Thank you, worked like a charm
- de
22pf capacitor 50v?
- de
It worked like a charm ! THANKS !! How did you find this solution ?
- de
hello do you have to regulate your problem??
Puntuación 0
Hello all. My SoundDock Series II does the same thing. For a while the green LED would stay lit after a power outage, but would be fixed by replugging the power cable on back of unit -- now that method doesn't work. I suspect there is an issue with the power supply, or with the power stable circuit. I will pursue this problem and post any conclusions.
Puntuación 0
1 comentario:
Would like to know what the fix is for this issue when it's available, would like my SoundDock working again.
Thanks.
- de
Añadir tu respuesta
Romer Alvarado estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 26
Ultimos 30 días: 117
Todo El Tiempo: 6,833
