Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fecha de lanzamiento: 24 de enero de 2008; 8 MP, zoom óptico de 3x, sistema de estabilización de imagen óptica integrado y software de detección de rostros; Procesador de imagen DIGIC III.
Why is my camera not focusing
when i aim the camera it is out of focus. if i zoom in a bit it will focus
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
In the Canon SX200IS which I'm familiar with, the focussing lens is the last element before the sensor, and this moves in and out on a brass insert which engages in a leadscrew. (See my SX200IS Lens Disassembly Guide for a full description.) It's likely that your lens is a similar design, in which case I would suspect that this mechanism is faulty and only works on part of its travel. I saw an example of a heavily used camera (probably many thousands of exposures) where the thread on the brass insert was so worn as to no longer work. This could be your problem. Not having access to watchmaker's tools, the only way I could fix it was to cannibalise the part from another broken camera.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
bebrouse estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 2,468
