Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
Pantalla LCD panorámica de 4,3" con un procesador de 333 MHz. Número de modelo PSP98510. La reparación de este dispositivo requiere destornilladores comunes y herramientas de palanca.
Preguntas 20 Ver todo
Is my PSP bricked?
Hello! I got this used PSP 2001 off of Ebay. I connected it to my laptop and may have accidentally deleted some or all operating system files (Unchecked "Hide Operating System Files). The system would turn on, but I couldn't open any of the system settings... Then, it shut off and refuses to turn back on.
When turned on, the green light lights up but the screen is black. If I turn it on with the R button pressed down, the backlight of the system lights up with the blank screen.
Is my psp bricked, or is it an internal problem?
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Respuesta Más Útil
You can't mess with flash0 from USB mode.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
You can with custom firmware.
- de
Hey Em, since the green light isn't blinking, I can sort of confirm that it isn't a fully bricked device. Try this. If that doesn't work, try this.
-Let me know how it goes.
-Please accept this as the answer if it answered the question.
Puntuación 0
2 comentarios:
Hey Apple! I have tried the first method but didn't work. Saw the second video, but wanted to hold that method off until my Pandora battery and MMS arrives (I just ordered one just in case). Thanks!
- de
Seems like I did brick the PSP. I seemed to have messed with the Flash0 files by accident!
- de
I could describe what I found, but it's easier for me to just send over a link:
https://www.youtube.com/watch?v=qoCD7WuZ...
I think you will find all you need here. (skip the first method as you obviously tried that already)
Tell me how it went!
Puntuación 0
2 comentarios:
Hey wantomek! I watched the video but realized that all of the methods consisted of using the recovery mode. Not sure if I can try these methods without recovery mode. Also, I am unable to connect the psp to my laptop (USB mode) since it won't turn on at all. As of now, I can only open up the memory stick using a reader on my laptop, which I am told is different from getting to the system files itself. I don't see "kd" or "font" file when the MS is opened via the reader.
- de
- de
Is your PSP modded in any way? If you power it on with the battery out but the charger cable plugged in do you hear any sounds if the volume is up all the way and you press buttons?
If it’s bricked there are ways to recover depending on what motherboard revision you have. If you have an older one you just need a Pandora battery and a memory stick programmed with Despertar Del Cemeterio v9 so you can have firmware 6.60 installed. If you have a newer motherboard then you need a Baryon Sweeper battery and afaik you can use regular memory sticks but they will need to be modified with the newer ipl.bin to work with a newer motherboard.
Pandora batteries and preprogrammed memory sticks can be bought but I don’t know anyone selling Baryon Sweeper batteries and you need to have decent soldering skills just to assemble them and good computer skills to use them or program them depending on the method you choose. I’m still waiting on parts to arrive so I can make a Baryon Sweeper battery to fix my 3001 that I purchased bricked. I was Planning on making some to sell but they’re going to be around $30-$40 or so before shipping depending on the price of the parts at the time.
Pandora Battery Guide:
https://gbatemp.net/threads/pandora-mms-...
DDC v9:
https://wololo.net/talk/viewtopic.php?t=...
Baryon Sweeper Links:
https://twitter.com/balika011/status/137...
https://github.com/balika011/BaryonSTM
Puntuación 0
Añadir tu respuesta
Em estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 54
Todo El Tiempo: 13,461
