Saltar al contenido principal
La tercera generación de tabletas de color Nook de 7 pulgadas de Barnes & Noble, que no debe confundirse con la Nook HD + de 9 pulgadas.
Preguntas 20 Ver todo
My nook will not turn on. what do I do?
I have tried so many things and nothing is working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
1 comentario
I have a nook its not HD i have this same issue Please Help me
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
your nook wont turn on because it is overheated.if your nook will not turn on then try charging it.
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Why would my nook be overheated?
- de
Unlike a laptop which has a built-in fan to keep the unit cool. The Nook battery will get hot even w/ a few hrs use as most of the time its laying in ur lap or on a flat surface where no air can circulate & the heat from the battery has no place to go building up & overheating then ur Nook usually freezes & u have to reboot. Makes me so mad! To minimize this hassle, my remedy is when possible I keep a small fan @ my workstation to put by my nook & I try to remember not to lay it flat but prop it up to let air circulate. No more overheating, yeah!
- de
Your nook is over heattd because you have been useing it to muçh.all things that you downloaded or the built in apps take up spaces.When you take up to much space your battery drains faster and makes it over heat easier
- de
You need to see what you're using when it overheats. Close the apps you are not using at the moment. Uninstall the apps that you are not using often; keep them in the cloud. Try not using your nook while it's charging.
- de
My Tablet Nook HD Won't Turn on but it Will just charge
Puntuación 0
I had the same thing happen. I just took it of the charger and left it for 2 weeks. I tried it again and it worked. May be different for you but it worked for me.
Puntuación 0
I'm thinking you might need a new battery
Puntuación 0
Añadir tu respuesta
Kristin McAlister estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 6,553
