Saltar al contenido principal
Canon PowerShot Una cámara de apuntar y disparar de la serie lanzada en 2006, con una cámara de 6.0 megapíxeles y lente de zoom óptico 4x.
Preguntas 7 Ver todo
recently started taking solid black pictures
up until recently, my camera works perfectly. Then about a week ago, it started taking solid black pictures. When trying to take a photo I can only see black in the screen. However, I can see previously taken pictures in the screen. I saw this problem listed under the S series. I tried the resolution by looking down the zoom lens,but I can see the "Flicker". Could this be something else? How can I fix it?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Shelly, could be that the OPTICAL UNIT is defective. (The shutter in the LENS part is not opening). It is also possible that you have a CCD sensor error. Usually a replacement of the lens assembly will resolve it, but there is always a possibility that it is an issue of the CCD circuitry on the mainboard. I'd start with a new lens. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Shelly estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 229
