The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 19
Todo El Tiempo: 12,787
