Saltar al contenido principal
Honeywell HY-204 Fan Motor Replacement
Qué necesitas
  1. Honeywell HY-204 Fan Motor Replacement, Case: paso 1, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement, Case: paso 1, imagen 2 de 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: paso 2, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement: paso 2, imagen 2 de 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: paso 3, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: paso 3, imagen 2 de 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: paso 4, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement: paso 4, imagen 2 de 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: paso 5, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: paso 5, imagen 2 de 2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: paso 6, imagen 1 de 2 Honeywell HY-204 Fan Motor Replacement: paso 6, imagen 2 de 2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 10-40, Amido Fall 2014 Miembro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
Miembros de 3
7 Guías creadas
2 comentarios
Where do you purchase the replacement fan motors from?
mattb - Contestar
Do you know where I can find the fan motor replacement?
Dave Smith - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 6,646
